LDAP users can not log in the End User Web Page CCM6
May 31st, 2009
CCM version: 6.1.1.2000-3
I enabled Synchronizing from LDAP Server.
I created LDAP directory.
I enabled LDAP Authentication for End Users.
After LDAP synchronization process End Users from LDAP were appeared in CCM. Everething is correct.
The problem is if I try to log in at End User Web Page with user login and password from AD CCM says that Login or Password is not correct.
But if I turn off LDAP synchronization and create an End User manually I log in to End User Web Page succesfully.
Is it possible to log in to End User Web Page for LDAP User ?
Overall Rating: 1 (2 ratings)
david-lima Tue, 06/02/2009 - 05:42
Hi friend, just as an advice, did you try to reset the user password from LDAP and try to login again?
All the best
David.
Dennis Mink Wed, 06/03/2009 - 03:39
go into the CUCM admin pages and go to user management, make sure you add the appropriate permission to you user, CCM user will do, also make sure you associate a phone with this user.
vyacheslav.k Thu, 06/04/2009 - 17:11
All End Users have appropriate permissions.
I've found the problem:
the LDAP Authentication argument 'LDAP User Search Base' refered to LDAP Branch which did n't contain any User.
Thanks to all.
