pickup while talking
Answered Question
May 31st, 2009
Question:
Is it possible to pickup another line when you are already talking?
I would assume this:
You talk with someone, you put the line on hold, and pickup another line, make a small talk and close the line and resume the original line.
The softkey template does not have the pickup button for an on-hold situation.
Might this be implemented in the future?
JH
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Jan,
I just tested this our lab and found that this can work :) Put the first call on Hold > Select "New Call" Softkey > Pickup > Call is properly redirected to you via Pickup.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 06/01/2009 - 04:23
Hi Jan,
Hope this helps!
Rob
