log error
hi! I've the following error in my routers and switch. Is this a hardware error? or what can i do to rectified this? Thanks.
Core Switch
corp2> (enable) sh counters supervisor
Forwarding Engine Error Stats Counters
IP len against Physical length err = 0
IP min. length check error = 0
IP pkts with cksum error = 4
IPX len against Physical length err = 0
IPX min. length check error = 0
%MROUTE-4-MTU_MISMATCH: WARNING: With IP multicast enabled, in
terfaces which transmit traffic from larger to smaller MTU interfaces may not be
hardware switched due to fragmentation. A degradation in performance may occur.
Overall Rating: 4 (1 ratings)
cisco_lad2004 Mon, 06/01/2009 - 05:17
Ensure MTU size is same size in interfaces between Router and Switch.
cisco_lad2004 Mon, 06/01/2009 - 09:03
sh int x/y | inc MTU
This must be checked on both adjacent devices Link interfaces.
Jayakrishna Mada Mon, 06/01/2009 - 22:45
IP pkts with cksum error = 4 means that switch has received a bad packet ( packet with checksum error).
The other messages is just a informational message.
