Connect 800 and 2600 series router.
Jun 1st, 2009
Hi All,
I need to connect 800 series router to 2600 router. 800 series is main router and connected with ISP. I have four ethernet port on 800 series router. 2600 series router is for internal IP phone (7960) connection testing. 2600 series has only one ethernet port. What card do i need to use on the 2600 series router to connect with 800 router aslo with Poe Switch+IP phone.
Thank you,
sivaprakasam81 Mon, 06/01/2009 - 06:01
Hi All,
What are all the interface card, can i use to connect 800 router from 2600 router?
Leo Laohoo Mon, 06/01/2009 - 13:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If your 2600 can support the IOS, NM-1E or NM-2E would work. This depends on the specific model of your 800. There are models of the 800 that has a 4-port Layer-2 only switch or none at all.
Hope this helps.
