Unable to connect 6704 to 6708.
Jun 1st, 2009
Has anyone had issues connecting 7604 with 6704 Zenpack 10Gbase-SR to a 6506-E with WS-X6708-10GE with X2 10Gbase-LRM? I am using MMF 62.5 fiber. The fiber test clean but the ports are not coming up.
viyuan700 Wed, 06/03/2009 - 05:37
  • Silver, 250 points or more
They are not coming up as 10Gbase-SR works on 850nm and 10Gbase-LRM works on 1310nm. Both have different wavelength. You have to change one so that both works on same wavelength.
Check the following link
https://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa.html
One more point you have to consider if you are using 62.5MMF (which is considered as OM1)with 10Gbase-LRM. To get 220m of distance you need mode conditioning patch chord.
Check your distance and see whether you need 10G SR or LRM card.
