SIP trunk setup with CCA2.0
Jun 1st, 2009
  • Bronze, 100 points or more
Hi, I found an issue with CCA2.0. I setup a bogus SIP trunk as aplace holder, and went back and setup the proper information once I had it. I was saving in CCA all along with way. I setup the correct SIP information, then saved it. Once I went back into CCA, the old information was back and none of the new information was in place.
I entered it all in via the command line then it worked properly. It looks like the save in CCA 2.0 is somewhat suspect.
Cheers
