I cannot hear busy signal in my cisco Phone
Answered Question
Jun 1st, 2009
Hello everybody,
I am appreciating your help on my issue, I cannot hear busy signal in my cisco
phone, an example when I picked up the Cisco phone and other person is
calling me he cannot hear the busy signal.This problem happened when the call received internally or externally
This is show run:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip subnet-zero
isdn switch-type primary-4ess
voice-card 0
dspfarm
dsp services dspfarm
voice translation-rule 1
rule 1 // /0/
voice translation-rule 5
rule 1 /^$/ /6445/
voice translation-profile FAXDID
translate calling 5
voice translation-profile Incom
translate calling 1
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital r2-compelled ani
voice-port 0/0/0:0
translation-profile incoming Incom
voice-port 0/0/0:1
voice-port 0/1/0
supervisory disconnect dualtone mid-call
--More-- timeouts interdigit 4
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 5
timing hookflash-out 50
connection plar 5552
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
sccp local GigabitEthernet0/0
sccp ccm 10.10.20.3 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CFB001ef7ed0e10
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
--More-- !
dial-peer voice 999026 pots
incoming called-number 6[4-5]..
direct-inward-dial
port 0/0/0:0
dial-peer voice 9898 voip
description ********
preference 1
destination-pattern 6465
session target ipv4:10.10.20.13
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 999998 voip
preference 3
destination-pattern 6[4-5]..
session target ipv4:10.10.20.4
incoming called-number .T
dtmf-relay h245-alphanumeric
codec g711ulaw
--More-- no vad
dial-peer voice 999027 pots
preference 3
answer-address 6[4-5]..
destination-pattern .T
port 0/0/0:1
dial-peer voice 6445 voip
description ****DID FAX ****
preference 1
destination-pattern 6445
codec g711alaw
no vad
dial-peer voice 2002 voip
description ***OUTGOING FAX FROM TO PSTN****
incoming called-number 6445
codec g711alaw
fax rate 14400
--More-- fax protocol t38 ls-redundancy 0
hs-redundancy 0 fallback cisco
no vad
dial-peer voice 6491 voip
preference 1
destination-pattern 6491
codec g711alaw
no vad
dial-peer voice 6450 voip
preference 1
destination-pattern 6451
codec g711alaw
no vad
dial-peer voice 6481 voip
--More-- preference 1
destination-pattern 6481
codec g711alaw
no vad
dial-peer voice 6405 voip
preference 1
destination-pattern 6405
codec g711alaw
no vad
dial-peer voice 999999 voip
preference 2
session target ipv4:10.10.20.3
codec g711ulaw
--More-- no vad
dial-peer voice 5550 voip
description **** IPCC****
destination-pattern 555[24]
codec g711ulaw
dial-peer voice 5551 voip
preference 5
codec g711ulaw
Correct Answer by paolo bevilacqua about 7 years 10 months ago
Very good, please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (2 ratings)
gogasca Wed, 06/03/2009 - 23:18
  • Green, 3000 points or more
hi,
"I cannot hear busy signal in my cisco
calling me he cannot hear the busy signal.This problem happened when the call received internally or externally"
Are using CUCM, CME?
What you hear instead?
If CUCM whats busy trigger under DN (Directory Number configuration)?
If CME do you call-waiting?
alhaddad1000 Thu, 06/04/2009 - 03:06
Thanks a lot for paying attention to my concern, I am using CUCM version 6 and whenever the line is busy I am hearing normal dial tone, you can check the existing configuration in my previous e-mail
I am appreciating your help on this matter
Thx,
paolo bevilacqua Fri, 06/05/2009 - 03:50
  • Hall of Fame,
    Founding Member
Check your busy trigger config under relevant DN, you need to set to 1 in order to get a busy signal on a 2nd call.
alhaddad1000 Sat, 06/06/2009 - 02:54
Thanks a lot for all who paid attention,
my problem resolved,
Correct Answer
paolo bevilacqua Sat, 06/06/2009 - 07:00
  • Hall of Fame,
    Founding Member
