Giuseppe Larosa Mon, 06/01/2009 - 10:23
  • Hall of Fame,
    Founding Member
Hello Aaron,
there can be another telnet/ssh session where a sh run has been given and the session is stucked at a more prompt.
check with sh users if there are other sessions.
There is an option that provides exclusive access to running config.
Hope to help
Giuseppe
ronshuster Mon, 06/01/2009 - 10:33
I am not sure this is the problem as now I can see the config but it can take a few minutes until it pops up on the screen. The switch was rebooted 2 days ago.
Giuseppe Larosa Tue, 06/02/2009 - 00:49
  • Hall of Fame,
    Founding Member
Hello Aaron,
as noted by Leo you may be hitting a SW bug.
To help narrow the search more details are needed, if you can attach a sh ver and sh module
Hope to help
Giuseppe
Leo Laohoo Mon, 06/01/2009 - 13:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Aaron,
What's your IOS? Sounds like you've just hit an IOS bug.
Hope this helps.
ronshuster Tue, 06/02/2009 - 08:29
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Nov-06 06:50 by kellythw
Image text-base: 0x40101040, data-base: 0x42D98000
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
coresw uptime is 2 days, 5 hours, 53 minutes
Time since coresw switched to active is 2 days, 5 hours, 53 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 06:25:06 EDT Sun May 31 2009
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-NEB-A (R7000) processor (revision 1.2) with 458720K/65536K bytes
of memory.
Processor board ID FOX1022088D
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
6 Virtual Ethernet/IEEE 802.3 interfaces
122 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
