MGCP Name Display with NI-1 using DMS-100
Jun 1st, 2009
MGCP PRI linked to Allstream. MGCP is configured DMS-100 Switch type while Alstream are using a DMS 500 emuling NI-1 swith type. Name display do comes out on Q931 Message out to Allstream.
But Allstream are asking for:
You need the plus/minus byte in front of the name. Nonetheless, NI2 will not work in the SS7 network. If they do change to NI-1 they must also add that byte. Example:DSP: ±DANIEL THOMPSON
I did attach the way the presentation is requested.
Is it compatible ? what can we do ?
--------Char----Decimal---Hex-----Binary
space-----------32--------20------00100000
plus---- + -----43--------2B------00101011
plus/
minus--- ± -----177-------B1------10110001
Note: If you get #NAME? in the hex and binary columns, go to Tools -> Add-Ins, and select "Analysis ToolPack"
javierrodriguez... Fri, 11/14/2014 - 07:53
I am not sure if you successfully fixed this. I am having the same issue in CUCM 9.1
