XML files dont copy to standby unit
Jun 1st, 2009
I have failover active/standby topology with two ASA (version 8.0.4), and Clientless SSL VPN configured.
I have created differents profiles, bookmarks and portal in this solution.
But when I try to see this files in the standby unit, I can't to see it. Why? I try it whit "write standby" but nothing... Any idea?
Best regards
vmoopeung Fri, 06/05/2009 - 13:15
  • Bronze, 100 points or more
The write standby command replicates the configuation to the running configuration of the peer unit; it does not save the configuration to the startup configuration. To save the configuration changes to the startup configuration, use the copy running-config startup-config command on the same unit on which you entered the write standby command. The command will be replicated to the peer unit and the configuration saved to the startup configuration.
http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/uz.html#wp1567205
