vpn conection to a Cisco WRVS4400N with QuickVPN
Jun 1st, 2009
> > Greetings,
> > I'm trying to make a vpn conection to a Cisco WRVS4400N with QuickVPN but
> it's not working.
> > Client:
> > XP sp3
> > QuickVpn
> > windows firewall: off
> > <http://192.168.100.1/portrangetriggering.htm> Port Range Triggering open
> for port 443 and 60443
> > <http://192.168.100.1/appgaming.htm> Port Range Forwarding open for port
> 443 and 60443
> > <http://192.168.100.1/VPNPassthrough.htm> VPN Passthrough enable for all
> > MTU: Manual = 1300
> > Host:
> > WRVS4400N
> > Client vpn acount created
> > block wan request: disabled
> > all firewall settings are disabled
> > MTU: Manual = 1400
> > I can ping the remote router.
> > Log file:
> > 2009/05/30 13:41:38 [STATUS]OS Version: Windows XP
> > 2009/05/30 13:41:38 [STATUS]Windows Firewall is OFF
> > 2009/05/30 13:41:38 [STATUS]One network interface detected with IP address
> 192.168.100.100
> > 2009/05/30 13:41:38 [STATUS]Connecting...
> > 2009/05/30 13:41:39 [STATUS]Connecting to remote gateway with IP address:
> 89.180.122.151
> > 2009/05/30 13:41:49 [WARNING]Remote gateway wasn't reached...
> > 2009/05/30 13:41:49 [WARNING]Failed to connect!
> > wget_error file
> > --13:41:39--
> https://arqsize:[email protected][email protected]ER=arqsize
=> `C://Program Files//Linksys//Linksys VPN Client//vpnserver.conf' Connecting to 89.180.122.151:443... failed: Unknown error.
Giving up.
Can you help me?
Best Regards
Andre Miguel
