ACS 1112 Problem
Jun 1st, 2009
Hi Guys,
I have re-imaged my ACS and I cant set and IP to it in the initial configuration, after setting up administrator account here is the error encountered "Error: Failed to get NIC configuration: (null) (FFFFFFFF)". I am using ACS-1112.
Appreciate your help. Thanks in advance.
Overall Rating: 4 (1 ratings)
huangedmc Mon, 06/01/2009 - 18:36
This question is better suited under Security.
The ACSSE should come w/ two NIC's.
Try the other one.
I had a very similar problem w/ one of our 1113's.
Even though the documentation says you should use NIC1, TAC said NIC2 works as well.
So after I moved the cable to the other NIC it magically started working again.
gagamboy15 Mon, 06/01/2009 - 18:47
Thanks Huangedmc, I already did that, try to used the NIC2 but still does'nt work.
I'll post this to Security section. Thanks again.
