ASA 5510 issue
Answered Question
Jun 1st, 2009
Dear All,
I applied ASA 5510 in my network,
I configured 3 interfaces DMZ, Inside and Outside
From the ASA, I can access Inside, DMZ and Outside (Internet)
Inside users can communicate with DMZ Servers
Inside users can goto Internet via outside interface
DMZ servers can goto Internet via outside interface
DMZ servers CANNOT Ping Inside network
I was using IpSec VPN on my router,
clients connect to the router using Cisco VPN Client software,
NOW, when I included ASA in the network, VPN clients are unable to communicate with DMZ servers
security level 0 for outside
50 for DMZ
100 for Inside
NAT is off using no nat-control command
Do I need to ON the NAT and some ACL should be in place...
Please advise me, what ACL should I implement, interface? direction?
What NAT statement should I include?
I want to access my network via VPN...
Please Help
Junaid
Correct Answer by Farrukh Haroon about 7 years 10 months ago
ICMP Pings are not stateful. The firewall needs special handling to dynamically permit the pings back, this is done via the 'ICMP inspection'. By default the ICMP inspection is disabled. You can either enable inspection or use an ACL to permit the ICMP traffic. Here is a useful link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml#topic0
Please rate if helpful.
Farrukh
Overall Rating: 5 (1 ratings)
mvsheik123 Tue, 06/02/2009 - 12:56
  • Gold, 750 points or more
Low Sec (DMZ)--> High Sec (Inside)- you need to create a acl. Try this...
access-list dmz_2_inside extended permit icmp any any
access-group dmz_2_inside in interface DMZ
hth
MS
Correct Answer
Farrukh Haroon Tue, 06/02/2009 - 22:09
  • Red, 2250 points or more
Farrukh
junshah22 Wed, 06/03/2009 - 02:50
Dear Farrukh,
Your provided link resolved my issue,
Where are you from?
THANKS,
Junaid
Farrukh Haroon Wed, 06/03/2009 - 02:56
The place where millat tractors are famous :)
Farrukh
junshah22 Wed, 06/03/2009 - 07:21
Shahdara??? Millat tractors is very next to Begum kot..
I was using NAT on the Router for my Microsoft Exchange Server with this command,
ip nat inside source static tcp 192.168.1.16 25 interface fastethernet 0/1 25
After placing ASA in the network, It is not working,
I check it from the Internet by telnetting my live ip on port 25, for example
55.55.55.55 25
It doesn't respond now,
VPN traffic was also not permitted for accessing Servers in DMZ,
After placing the ACL in the ASA, VPN traffic is permitted but NAT for MS-Exchange is not working,
I temporary allowed all the traffic in the ASA for checking purpose
permit ip any any
permit tcp any any
permit icmp any any
DO I NEED TO NAT it again in the ASA or NAT interface and IP will be change?
Secondly, I would appreciate if you give me your mobile number, so I can better explain,
Junaid
Farrukh Haroon Thu, 06/04/2009 - 06:12
No you don't need to NAT again. You just need to permit it in the outside interface ACL.
Where is the 192.168.1.16/x network lie? Is this same as the ASA inside network? Is your routing setup correctly?
Did you add a route on the router to send 192.168.1.x to the ASA?
Farrukh
junshah22 Thu, 06/04/2009 - 06:22
192.168.1.16 is directly connected with ASA DMZ interface
DMZ IP, 192.168.1.18
when I connect via vpn, I can remote desktop my server,
Junaid
Farrukh Haroon Fri, 06/05/2009 - 23:05
If you telnet to the public IP of the mail server from outside, what happens?
Did you add a route on the router to send the 192.168.1.x subnet to the ASA?
Farrukh
junshah22 Sat, 06/06/2009 - 00:04
192.168.1.x subnet is directly connected with ASA (DMZ interface)
I dont think so there is any need of adding a static route in the ASA towards 192.168.1.x subnet
When I telnet my public ip, it shows a message, (Press any key to continue) when I press any key, it shows, connection to the host lost,
telnet
o 55.55.55.55 25
Before Adding ASA, It connects to my mail server successfully,
I added a route in the Router
ip route 192.168.1.0 255.255.255.0 192.168.74.2
where 74.2 is the ASA directly connected interface with the Router
and 192.168.1.x is directly connected with ASA (DMZ Interface)
Junaid
Farrukh Haroon Sat, 06/06/2009 - 23:54
Were you able to solve this issue?
I tried to post yesterday but the forum was not working.
Can you try disabling ESMTP inspection?
Farrukh
