Does C12816 can configuration flow mirroring?
Jun 2nd, 2009
We want mirroring the RTP traffic from C12816 to my box, does C12816 support this function? if it support, how to configure.
Thanks!
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 06/02/2009 - 00:54
  • Hall of Fame,
    Founding Member
Hello Shaofei,
a C12816 is a very powerful router but it hasn't SPAN capabilities like a LAN switch.
You need to add a LAN switch with SPAN capability: you configure two ports in the same L2 vlan and then you can use SPAN to mirror traffic coming from the GSR interface.
A packet capture feature has been introduced in 12.4T for ISR routers but it is not available for GSR.
Hope to help
Giuseppe
