If you have static routes, you can redistribute your static route into OSPF. If you want just your VPN pool redistributed, you can redistribute it with a route-map only, and then deny everything else (unless you're using OSPF for everything on the ASA).
HTH,
John
HTH,
John
*** Please rate all useful posts ***
