unable to upgrade MDS9500 ??
Jun 2nd, 2009
hello
got strange error message trying to upgrade mds from 3.0.2A to 3.3.3
can somebody explain and help me to resolve this issue
thanks
JYP
install all kickstart bootflash:m9500-sf1ek9-kickstart-mz.3.3.3.bin system bootflash:m9500-sf1ek9-mz.3.3.3.bin
^[[ACompatibility check failed. Return code 0x40930041 (not enough space on standby supervisor disk).
Overall Rating: 0 (1 ratings)
Michael Brown Tue, 06/02/2009 - 01:54
  • Cisco Employee,
As part of the upgrade the 2 images are copied from the active supervisor, the one the box is currently operating on, to the backup supervisor. What this message is saying is that the standby supervisor does not have enough free storage to hold both images.
Issue this command to see what supervisor you are on.
show mod
Look for the module with the status of Standby.
Then issue this command to attach to it.
attach module x (x is the number of the module).
The prompt should show (standby) in it at this point.
Now you can issue this command to see the files on the bootflash:
dir bootflash:
Erase any old images with the command
del bootflash:
Once completed, issue the 'exit' command to return to the active supervisor, and attempt the upgrade again.
Hope this helps,
Mike
Arumuga Raj Sha... Thu, 02/07/2013 - 23:21
Thanks Mike... i am also facing the same problem... while upgrading MDS to latest firmware... but now i solved using your inputs... once again thanks a lot... this will help more.
Trending Topics: Storage Networking
