IP access restriction in 3560
Answered Question
Jun 2nd, 2009
Hi everybody,
I am configuring 3560 switch. I have the basic requirement. I want to configure a swithc port fa 0/0 to allow only the IP address for example and deny any other PCs with IP address other than this.
I want to retain the port fa 0/0 as switch port only. I know to donot want to configure mac ACL. Can you guide me how to achieve this.
Correct Answer by glen.grant about 7 years 4 months ago
Overall Rating: 5 (1 ratings)
mahmoodmkl Tue, 06/02/2009 - 02:39
If u r sure that the switchport will not change for this PC u can use port security to achieve this.
switchport port security
switchport port security mac-address sticky
hclisschennai Tue, 06/02/2009 - 06:24
Hi Mahmood,
Thanks for reply.
But I suppose that switchport port security mac-address sticky is for MAC address and not for IP address attached to the port.
Can you pl. explain how this command help in my scenario
hclisschennai Tue, 06/02/2009 - 09:24
Your idea is good, but "mac-address sticky" will check the MAC address associated with the ports & donot care about the IP address of the server connected.
I can very well use either port ACL. But want to know any other alternative solution similar to port security "mac-address sticky "
