Controller E1 , firmware is not running
Jun 2nd, 2009
Hello All,
I have this error msg that appears on my cisco 1841 routers:
%CONTROLLER-2-FIRMWARE: Controller E1 0/0/0, firmware is not running
i installed VWIC2-2MFT-G703 cards on my routers and i want to use it for my WAN communications to transfer the data (not voice) but this msg appears.
please see the output of show version command:
(sho vers
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(21a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 29-Sep-08 14:48 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
HQ uptime is 6 minutes
System returned to ROM by reload at 09:57:48 UTC Tue Jun 2 2009
System image file is "flash:c1841-advipservicesk9-mz[1].124-21a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1841 (revision 6.0) with 115712K/15360K bytes of memory.
Processor board ID FCZ09403270
2 FastEthernet interfaces
1 Serial interface
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102)
show intve
(sho invento
NAME: "chassis", DESCR: "1841 chassis"
PID: CISCO1841 , VID: V02 , SN: FCZ09403270
NAME: "WIC/HWIC 0", DESCR: "VWIC2-2MFT-G703 - 2-Port RJ-48 Multiflex Trunk - G.703"
PID: VWIC2-2MFT-G703 , VID: V01 , SN: FOC12081QKL)
the card appears in output of show version and show inven commands but keep showing me that error.
please note that i upgraded router to different IOS images:
c1841-advipservicesk9-mz.124-21a.bin
c1841-advipservicesk9-mz.124-23.bin
c1841-spservicesk9-mz.124-15.T9.bin
c1841-advsecurityk9-mz.124-23.bin
but still get the same error. i searched on the internet and cisco docs but i didnt find real answers to what is causing this issue.
any ideas.
Eng.Sameer Abduh
Network Engineer
Dennis Mink Thu, 06/04/2009 - 05:20
  • Gold, 750 points or more
did you add the controller e1 0/0 (or whatever slot it is added to) to your
config?
can you issue "show controller e1 0/0" at all?
sameero10 Sat, 06/06/2009 - 22:19
yes i added it to the config, and it created the serial logical interface,is it hardware issue? pinout assignment of the cable used? or configuration issue?
check the configuration below:
Router# sho running-config
Building configuration...
Current configuration : 1960 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
ip domain name yourdomain.com
username privilege 15 secret
controller E1 0/0/0
clock source internal independent
channel-group 0 timeslots 1-31
interface FastEthernet0/0
description Router-Lan
ip address 192.168.2.1 255.255.255.128
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
ip address 10.2.2.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 10.2.2.2
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
disable-eadi
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
Router#
*May 31 11:45:55.403: %CONTROLLER-2-FIRMWARE: Controller E1 0/0/0, firmware is not running
Router#sho interfaces
FastEthernet0/0 is up, line protocol is down
Hardware is Gt96k FE, address is 0017.5963.38b4 (bia 0017.5963.38b4)
Description: Router-Lan
Internet address is 192.168.2.1/25
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
/// output suppressed
Serial0/0/0:0 is down, line protocol is down
Hardware is GT96K Serial
Internet address is 10.2.2.1/30
MTU 1500 bytes, BW 1984 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1488 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
0 carrier transitions
Timeslot(s) Used:1-31, SCC: 0, Transmitter delay is 0 flags
Router#
*May 31 11:46:05.403: %CONTROLLER-2-FIRMWARE: Controller E1 0/0/0, firmware is not running
Router#
Sam Abdo
Paolo Bevilacqua Sun, 06/07/2009 - 02:56
  • Hall of Fame,
    Founding Member
Recommend you engage TAC on this.
Ask that they reproduce the issue using the very same HW you have.
