How do I enable ip forwarding/routing on a cisco catalyst 2960
juxtapoz15
How do I enable ip forwarding/routing in cisco catalyst 2960?
I am currently running: Version 12.2(44)SE3
Giuseppe Larosa
Hello Mike,
C2960 should be a L2 only switch
check here
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/configuration/guide/swintro.html#wp1528661
so you should not be able to use it for inter vlan routing
Hope to help
Giuseppe
glen.grant
Layer 2 only , no routing on this switch.
Gary Stolp
Hello in some releases you can enable ip routing on a L2 switch c2960 with SDM preferences depends which IOS release you are running
(config)#sdm prefer lanbase-routing
This worked for me.
Gary
  Yeah this thread is 5 years old, before they enable routing on the 2960's.  Think you have to have at least 12.2.55 code also.
