L2TP over serial
Jun 2nd, 2009
I'm trying to create an L2TP tunnel between the LAC and LNS originating from a serial connection that enters the LAC from the CE.
I assumed you have to use a dialer interface to map the connection from the serial port to the tunnel.
I don't however have a number to use as the dialer string to configure the dialer interface. Is there a way to work around this or is there another method.
