Hi Andres,
You can still change the user PIN when authenticated with LDAP, what you cannot change is the Password as this is what is authenticated with LDAP.
You will need to reset the PIN through the CUCM Admin Webpage with your CCMadmin (admin) account.
HTH, Please rate if so
Justin
