06-02-2009 06:11 AM - edited 03-06-2019 06:03 AM
Hello All,
I am running this code Cisco Internetwork Operating System Software
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(18)EW
and I can not see anything about the EOBC interface with and show command.
Vlad
06-08-2009 07:40 AM
The EOBC is an internal interface that is not visible via the CLI and should not be visible via SNMP.
06-08-2009 08:30 AM
EOBC stands for Ethernet Out-of-Band Channel and is an internal communications channel in the modular switches (like Cat4500 and Cat6500). It is used for the control plane communication between the Supervisor(s) and the line card.
