Configuring IOS firewall Zone Based REMOTELY
Jun 2nd, 2009
Hi to all,
need to deploy the folling IOS firewall Zone Based configuration to a running remotely router.
I'M CONNECTED WITH SSH ...
HOW IS IT POSSIBLE WITHOUT DISCONNETING ME ?
(I know the reload command and also the rollback command).
Q1) When I try to insert on the 1st interface the "zone-member security trust" or "zone-member security untrust" I LOST THE ROUTER CAUSE THE OTHER INTERFACES ARE NOT CONFIGURED: HOW I CAN ACTIVATE THE ZONE-MEMBER COMMAND ON THE ROUTER WITHOUT LOST IT ?
Q2) it's possible (like Juniper JUNOS) made alla the new configuration and execute the "commit now" when I've finished ?
Q3) Is there any other feature on cisco IOS to allow to configure the router, check the configuration and only AFTER put it on the running config (the only tip i?ve found is to modify the startup config and load in or merge the running config with another conf...)?
* FOLLOWING THE NEW LINES CONFIGURATION:
class-map type inspect match-any untrust-trust-cmap
match protocol telnet
match protocol ssh
policy-map type inspect untrust-trust-pmap
class type inspect untrust-trust-cmap
inspect
class class-default
class-map type inspect match-any trust-untrust-cmap
match protocol tcp
match protocol udp
policy-map type inspect trust-untrust-pmap
class type inspect trust-untrust-cmap
inspect
class class-default
zone security trust
zone security untrust
zone-pair security trust-untrust source trust destination untrust
service-policy type inspect trust-untrust-pmap
zone-pair security untrust-trust source untrust destination trust
service-policy type inspect untrust-trust-pmap
interface FastEthernet0/0
int dialer 0
interface ATM0/0
Regards.
Roberto Taccon
Overall Rating: 3 (1 ratings)
Collin Clark Wed, 06/03/2009 - 06:04
  • Purple, 4500 points or more
1) You can't
2) I wish Cisco had that feature too
3) Not that I know of
The tip you have received is the only way I can think to do it. You don't need to modify the startup config. Enter the commands you want to configure the firewall in a text editor. Save the file and copy it to the flash directory on the router. Then copy the file from flash into running config. Do not save the config via the text file! You will lose connectivity, but if you did everything correctly you should be able to get back in. Of course this is pretty high risk. I would suggest entering reload in 15 which would reload the router in 15 minutes in case the config merge fails.
