block smtp outbound in IOS
Jun 2nd, 2009
I'm trying to figure out how to block outbound smtp access except from my exchange server. Here is the ACL i developed.
ip access-list extended SMTP
permit tcp 10.10.152.200 0.0.0.255 any eq smtp
deny tcp any any eq smtp
permit ip any any
I thought i would apply it outbound (ip access-group SMTP out) on my inside interface but when i do that I can no longer accept connections inbound to the server. Where should I have this? Is something wrong with the ACL itself?
Thanks Much!
jjohnston1127 Tue, 06/02/2009 - 06:44
  • Silver, 250 points or more
Try applying it to your inside interface, incoming (ip access-group SMTP in). It will look at traffic coming INTO the interface on the router and determine what to do with it. Remember, access-lists should usually be applied closest to source.
