RIP redistribution into OSPF
Answered Question
Jun 2nd, 2009
  • Purple, 4500 points or more
All,
I've attached a diagram for something that I ran into this morning. I have 2 ospf areas, one of which is an nssa, and I have a RIP router behind the nssa. I noticed that the same route that RouterB seen as an N2 route, RouterA sees as an E2 route. Is this because the ASBR is converting Type-7 LSA into a Type-5, and then RouterA is receiving the Type-5 LSA marking it as an external route, but not necessarily known that it came from an NSSA?
John
Correct Answer by Edison Ortiz about 7 years 9 months ago
To reiterate, Router A is not part of the NSSA so it will receive external routes as E1 or E2.
Router C is part of the NSSA (Area 1), so any external routes from a ASBR on that area (on this case router B) will be seen as N1 or N2.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 06/02/2009 - 06:39
  • Hall of Fame,
    Founding Member
John,
I don't see any diagram but if Router A is receiving this LSA via a regular area, it will see any external route as E2 instead of N2.
N2 LSAs will only be seen within the NSSA area.
HTH,
__
Edison.
John Blakley Tue, 06/02/2009 - 06:46
Ugh...forgot to attach the diagram.
Is RouterB seeing the external route as N2 because it's configured with area 1 as the nssa?
Thanks!
John
Correct Answer
Edison Ortiz Tue, 06/02/2009 - 07:10
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
