VRRP - Basic configuration
Answered Question
Jun 2nd, 2009
We have only two available IP address to be used for VRRP in basic configuration.
That is router interface physical IP becomes the virtual IP address of the VRRP group of two routers. If master fails then backup router will take the same IP address. ( but it will have different physical IP address).
Searched on cisco.com but could not find basic configuration. It says about using a third IP address as a virtual IP address or some kind of secondary IP address. Main thing is only two IP address are available and we need to configure redundancy.
Please share the experience.
Master IP = 10.10.1.1 /24
Back IP = 10.10.1.2 /24
Virtual IP of group = 10.10.1.1 ( same as that of master router ).
There is some drawback of this conf. as "tracking" can not be used to reduce the priority of Master router but that is ok, this is not mandatory condition for us.
Any link on cisco.com or any other URL is appreciated.
Thanks in advance.
subodh
Correct Answer by John Blakley about 7 years 9 months ago
Here's a link:
http://www.cisco.com/en/US/docs/ios/12_0st/12_0st18/feature/guide/st_vrrpx.html
If you have any further questions, let us know. Also, you're going to need two physical ip addresses and a virtual address that doesn't conflict with your physical.
Master IP = 10.10.1.2/24
Back IP = 10.10.1.3/24
Virtual = 10.10.1.1
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Tue, 06/02/2009 - 07:11
  • Purple, 4500 points or more
Here's a link:
Virtual = 10.10.1.1
HTH,
John
bapatsubodh Tue, 06/02/2009 - 07:59
Thanks so we need minimum three IP address.
Thanks again
subodh
rakesh.hegde Tue, 06/02/2009 - 10:44
Hi ,
VRRP can have router interface ip as the virtual ip. So, your set up would work with just 2 ips.
HTH,
Rakesh
