LMS 3.1/RME Config management
Jun 2nd, 2009
I want to save configurations of some switches with a "Secured Username" banner telnet access. It seems to work fine sometimes, but often it fails. What could be the problem?
Joe Clarke Tue, 06/02/2009 - 09:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What errors do you get trying to archive the config?
korrigan29 Wed, 06/03/2009 - 08:24
I've found a solution modifying the file $PX_DATADIR/objects/cmf/data/TacacsPrompts.ini with the good prompts for username and password.
It seems OK now.
