Music on Hold with a cell phone
Douglas Smith Tue, 06/02/2009 - 08:02
If you are you running both live feed and MOH from flash they may be conflicting. Please disable the live feed to verify.
Douglas Smith
Douglas Smith Tue, 06/02/2009 - 09:32
Can you please attach a show running config please.
I would expect to see something like the following:
moh minuet.wav
However I'd like to be sure no live feed configuration remains.
This would look something like the following:
voice-port 1/1/0
operation 4-wire
signal immediate
dial-peer voice 7777 pots
destination-pattern 7777
port 1/1/0
ephone-dn 55
number 5555
moh out-call 7777
Douglas Smith
I do have these lines:
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
voice-port 0/4/0
signal immediate
input gain auto-control -15
description Music On Hold Port
Should I remove them?
I just unchecked the live feed box in CCA.  That is the extent of what I did.
Douglas Smith Tue, 06/02/2009 - 15:03
Looks like both sections for external MOH are in your config, I believe disableing them will provide the result your looking for.
Please disable the ephone-dn 9.
To disable this via cli please issue
  ephone-dn 9
  no moh out-call ABC
Alternately we can disable the voice-port as well.
The voice-port 0/4/0 is the external MOH port,
disable external MOH port
  voice-port 0/4/0
Douglas Smith
