Enabling DOM on C3750G Switch
Jun 2nd, 2009
I have SFP-FE-Z transceiver module on a Gig port on my 3750G. I am unable to recieve any DOM stats even though the module is DOM capable. Cisco's site clearly indicates that this feature is not supported on the 3750G, yet a colleague assures me he is able to get DOM to work with the same configuration.
Do I need to enable Digital Optical Monitoring either globally, or on the specific interface for this feature to work? Thanks for your help.
jmaitzenfl Tue, 06/02/2009 - 07:55
Correction, I have SFP-GE-Z transceiver module on a Gig port on my 3750G.
Leo Laohoo Tue, 06/02/2009 - 14:55
If you enter the command show inter transceiver dom-supported-list you won't find this transceiver listed.
