06-02-2009 07:52 AM - edited 03-06-2019 06:03 AM
Hi, I am using cat4500-entservicesk9-mz.122-44.SG1.bin on my C4948. But I can find some QoS commands on it,such as mls qos, fair-queue, etc.The bandwidth, priority are also not under policy-map.
I think this IOS supports all kinds QoS features as Cisco Feature Navigator mentioned.
Can anyone advice? TIA
Solved! Go to Solution.
06-02-2009 08:56 AM
Please refer to the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/qos.html
The command to enable QoS is qos
Also, the switch does not provide extended MQC QoS features - the documentation list the supported commands.
HTH,
__
Edison.
06-02-2009 08:56 AM
HTH,
__
Edison.
