STP Question
Answered Question
Jun 2nd, 2009
Hi All,
If you have pvst+ configured in a network and one switch has a lower MAC address than all the others it will be the root bridge (assuming you havent set a any priorities).If you want to force that to be the root bridge and set a lower priority will this cause spanning-tree reconverge?
i.e Would this cause a brief outage on the LAN? Or should i schedule some downtime?
Many Thanks
Correct Answer by Edison Ortiz about 7 years 12 months ago
Any Spanning-Tree modifications should be done during a maintenance window.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Tue, 06/02/2009 - 08:50
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
serotonin888 Tue, 06/02/2009 - 10:50
Thanks Edison - I guess I was hoping I could save some time ;-)
I will schedule a maintainence window.
Thanks again.
mgreenbaum Tue, 06/02/2009 - 10:54
Any time that you change the root bridge on a PVST/STP environment, you will force a BPDU to go out to all the switches and a reconvergence to occur.
I would highly recommend scheduling some downtime.
I would also recommend looking into converting to Layer 3 connections between the devices to reduce and remove STP from the network. The routing protocols have a faster reconvergence than Spanning Tree in the event of a link failure. Check out some of the SRND documents on this at http://www.cisco.com/en/US/netsol/ns742/networking_solutions_program_category_home.html
