Cisco Unity 4.x failure
Jun 2nd, 2009
I have 2 cisco unity 4.x servers in a cluster configuration. The primary server crashed (blue screen) this was the server that changes could be made on. I restored the server from an image. I now have the two servers up and running. because the primary was restored it does not show the recent changes that were made. All the recent changes appear on the seconday server but it is read only. I was setting up an IVR using the Call Handlers. The recent Call handlers appear on the secondary but not on the primary. How do i get the call handlers to appear on the primary server where i can modify them.
Tommer Catlin Wed, 06/03/2009 - 12:30
You may need to re-run the failover wizard. If that fails, maybe try or use COBRAS to export the Callhandlers on the secondary, delete off secondary, re-import to the primary
At any rate though, it soulds like failover is broken pretty bad.
Tray Stoutmeyer Thu, 06/04/2009 - 11:03
You could just try forcing failover and failback. Part of that process is a SQL replication. It might get things synch'd up.
Tray Stoutmeyer Fri, 06/05/2009 - 07:10
Go to the primary server and open the failover monitor. Click the failover button. After about 20 minutes, go to the failover server and open the failover monitor. Click the failback button.
