MGCP Gateway T1: Is is up or down?
gmgarrian
Level 4
Level 4
I have a 2811 MGCP gateway in a CCM 4.X environment running IOS 12.4(8c). It has a T1 PRI for inbound calls. If I do a show interface on the router is shows the Serial 0/0/0:0 and all other timeslots (1-23) as down/line protocol down. However, the T1 is still registered in CCM and the last event logged in the router is that interface Serial 0/0/0:0 is up.
Since this configured for MGCP, would that cause this apparent contradiction? If I do a show mgcp endpoints they all show as up.
2 Accepted Solutions
At least that T1 is fine based on that output
java
if this helps, please rate
java
The b-channels are not required for any type of data and are a place holder in IOS. You are worried about the status of these commands:
show isdn status (multiple frame established)
show isdn service ( 0 is good state )
show controller t1
hth,
nick
5 Replies 5
Jaime Valencia
If you issue a sh isdn status what's the status?
You should clearly see the status there.
If you call what happens?
java
java
Calls are successful, but this is a resent port and I suspect the number was ported to the wrong T1 (there's another T1 at this site.
Here's the output from the sh isdn stat:
Global ISDN Switchtype = primary-ni
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not appl
y
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 13
Total Allocated ISDN CCBs = 0
java
java
show controller t1
hth,
nick
Based on that, everything looks good.
Thanks for the info.
