Change OSPF route types from E2 to Internal
Jun 2nd, 2009
Greetings all,
I need to change OSPF E2 routes to internal. I have tried to weight E2 to be preferred, but no luck. Is there a basic way to remark the routes?
slmansfield Wed, 06/03/2009 - 06:12
"distance OSPF" will allow you to adjust administrative distance based on route type.
The IP "distance" command will provide greater granularity to select specific routes.
