Presence question......?
We have 5 CCM Clusters in different locations. We have 1 Active Directory for all clusters and all locations have MOC.
We plan to add Presence to use MOC as a phone client..etc.
My question is...Do I need a Presence server or servers for each CCM cluster or can I use a single Presence server for all 5 CCM clusters.
Overall Rating: 4 (1 ratings)
htluo Tue, 06/02/2009 - 11:06
It depends on the integration model.
If you use CUPS to do MOC RCC (Remote Call Control), you need five CUPS servers.
If you use CUCIMOC plugin, you don't need CUPS at all.
Tommer Catlin Tue, 06/02/2009 - 15:01
So are you saying CUPS is going away soon or just not required if you are going to use the CUCIMOC? (assuming the cluster will need to be 7.1)
