Multiple IP's on SRW224G4
houstonjbw
I have a SRW224G4. I can create multiple VLAN's but when I try to create another vlan interface and add an ip address to it, I get the error message "ip address table overflow". Is this switch limited to having only 1 IP address? I would like to have 2 VLAN's, each with it's own VLAN interface and ip address. Is this possible?
chrcoope
Unfortunately this is not possible on an SRW224G4. If you want to talk to the switch from a VLAN other than the native VLAN, you should give it (the switch) a default gateway at minimum. The only Linksys switches able to have more than one IP address assigned to them are the layer 3 variety such as the SGE2010 when deployed in layer 3 mode.
Chris
