7925G Push to Talk (PTT)
Answered Question
Is there any way to configure the 7925G's PTT on UC520 for directed, point-to-point voice call as opposed to group paging? Much like the functions you get with Nextel / Mike handsets?
Correct Answer by Marcos Hernandez about 8 years 3 weeks ago
You could create more DN's like the one below:
ephone-dn  56
number 1201
label intercom
intercom 1200
And then add speed dials to those DN's. In other words, you build a "dialable" intercom that points to a unicast paging DN.
Let me know,
Marcos
Last year I was trying to mimic exactly what you were talking about.  A local hospital was looking at a two-way radio type of solution for their transporters (the folks who ferry patients from one place to another) and I proposed using a UC520 for this purpose.  The idea was to issue 7921 phones with headsets to the transporters and use the Wireless LAN throughout the hospital to transport the voice stream.  I coupled PTT with a PLAR function so that it would act just like a broadcast radio and mimic the two way radio.  I was jazzed when I figured out how to get it to work, the last piece of the puzzle I was able to get from the "Ask an Expert" area at last years Networkers...
Joe Rinehart, MBA, CCIE #14256, CCNP/DP/VP
President, Seattle Cisco Users Group
This is supported, but you will need CLI. See below for a sample config between a 7921 adn a 7925. I am using dummy MAC's and making up the ephone and ephone-dn's (you will have to customize to your setup).
In this example, the second line is the PTT line of both phones:
ephone-dn  50
number 1200
label ip-paging
paging
ephone-dn  56
number 1201
label intercom
intercom 1200
ephone  6
device-security-mode none
mac-address ABCD.ABCD.ABCD
max-calls-per-button 4
paging-dn 50 unicast
type 7921
no auto-line
button  1:39 2:56
ephone  41
mac-address BACD.BACD.BACD
type 7925
button  1:41 2:56
Let us know how it goes,
Marcos
Overall Rating: 5 (3 ratings)
Correct Answer
Marcos Hernandez Tue, 06/02/2009 - 20:49
  • Blue, 1500 points or more
ephone-dn  50
number 1200
label ip-paging
paging
ephone-dn  56
number 1201
label intercom
intercom 1200
ephone  6
type 7921
no auto-line
button  1:39 2:56
ephone  41
type 7925
button  1:41 2:56
Marcos
Thanks for the tip Marcos. However, is it possible to make the intercom not for a fixed number? The behavior I am looking for is much like what a user will get with Nextel/Mike PTT where the user will select someone/group from a list of and press PTT to open the com line (similar to Directory-Dial, but using Intercom instead).
Correct Answer
Marcos Hernandez Thu, 06/04/2009 - 13:26
ephone-dn  56
number 1201
label intercom
intercom 1200
Let me know,
Marcos
Marcos Hernandez Thu, 06/04/2009 - 13:27
One more comment. Make sure you honor the Out of Band Rules for CCA. That way you won't paint yourself into a corner if you still want to keep using CCA.
Marcos
Correct Answer
