Unity 5.0 Mailbox storage question
Answered Question
Jun 2nd, 2009
Hello, I have unity 5.0 voice mail only.
I want to increase the size of a user's mailbox because he doesn't want to delete the messages and the mailbox is full. the only way I found to increase the size is to go to ADUC>select the user> go to the Exchange General Tab and change the Storage limit to 1Gb.
do you know another way/better way to do it?
thanks
Correct Answer by Tommer Catlin about 8 years 1 month ago
Thats the best way to do it. There is a tool in the Unity Tools Depot, but it basically is just a script that does the same thing you are doing through the ADUC
Overall Rating: 5 (1 ratings)
Correct Answer
Tommer Catlin Tue, 06/02/2009 - 12:24
  • Green, 3000 points or more
