Question on IP Helper
Answered Question
Jun 2nd, 2009
Hello, setting up a new vlan and in adding the IP helper found out that we now have 2 PXE servers(Altiris) on another VLAN and need to account for both. Can there be 3 IP helpers with 2 of them being PXE servers? will that even work?
int vlan x
ip address <>
ip helper-address <DHCP server>
ip helper-address <PXE server 1>
ip helper-address <PXE server 2> ????
ip directed-broadcast 101
access-list 101 permit udp host <PXE server 1> any
access-list 101 permit udp host <PXE server 2> any
ip forward-protocol udp 402
Correct Answer by mahmoodmkl about 7 years 4 months ago
Yes u can have multiple helper-address uner u r interface.
Overall Rating: 5 (2 ratings)
Correct Answer
mahmoodmkl Tue, 06/02/2009 - 12:35
Eric Hansen Tue, 06/02/2009 - 12:40
Any idea if they round robin or anyting like that? Or do they process like an ACL?, which would basically make the second PXS helper useless.
Jon Marshall Tue, 06/02/2009 - 12:45
They are all used at the same time. So a DHCP request is sent by the router to each ip helper-address under the interface. Usually first one to reply to the router is the one used by the client.
Amit Singh Tue, 06/02/2009 - 12:47
The Cisco IOS can have multiple addresses listed with ip helper address pointing to each of the dhcp servers. With multiple helper-addresses configured, both servers would see the packets, but only the primary server for the scope would normally respond. This would depend on the servers end to distinguish which server would be the primary, there is not anything on the router or Cisco IOS that you can actually do to specify the primary or failover dhcp server.
-amit singh
yuttana_su Tue, 06/09/2009 - 21:55
Hi, asingh2
How many "ip helper-address" command per one interface?
Thank you.
