JORGE RODRIGUEZ Tue, 06/02/2009 - 13:45
You need SSL VPN solution for 64BitOS , WebVPN - Anyconnect client - Any ASA5500
See this link for all your Q&A section
SSL/IPsec VPN Services for the Cisco ASA Series
http://www.cisco.com/en/US/prod/vpndevc/ps6032/ps6094/ps6120/asa_ssl.html
Details in SSL licensing
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_brochure0900aecd80402e39_ns347_Networking_Solutions_Brochure.html
Clientless SSL VPN (WebVPN)
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00806ea271.shtml
See SSL VPN/Web VPN mid page down to learn different types of WebVPN/Annyconnect deployment scenarios
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html
PLS rate helpful posts
imranraheel Wed, 06/03/2009 - 01:35
jorgemcse
Some one told me of cisco vpn connect, would that work.
I need a client or some other solution than ssl
JORGE RODRIGUEZ Wed, 06/03/2009 - 07:57
Imran, they must have refered to Anyconnect client , the solution for the 64Bit OS is to use any SSL driven VPN technology. I provided the links for you to get you started , there is presentation link on SSL vpn technology. Cisco VPN client is 32 bit, there is no 64bit client version.
For your 64 bit RA clients use Either SSL WEB VPN or Annyconnect.
-Jorge
bauti1428 Wed, 06/03/2009 - 07:09
We have the same issue in our organization and unfortunately, Cisco VPN client is not supported on 64 bit OS. Anyconnect does support 64 bit.
Todd Pula Wed, 06/03/2009 - 07:46
AnyConnect is your only option and is supported on both the ASA and IOS platforms.
Phillip Remaker Fri, 02/19/2010 - 11:14
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
