c1721 with a WIC 1ADSL - PPPoE Trouble Configuration
Jun 2nd, 2009
I am having trouble to configure a c1721 with a WIC 1ADSL card.
Actually, I have a Cisco c827 working fine, but when I put the same configuration on the c1721, I am getting the message "01:40:23: Di1 DDR: Cannot place call, no dialer string set"
If I place the dialer string on the dialer interface, I get the message - "01:45:36: Di1: No free dialer - starting fast idle timer" either way I am getting
"01:46:06: Di1 DDR: cdp, 360 bytes, outgoing uninteresting (no list matched)" What sould I do? Thanks in advance.
This line only on the c1721.
dialer-list 1 protocol ip permit
Here is the configuration file:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Maxirede-via-GVT
username jonas privilege 15 password 7 ******
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip domain-lookup
ip dhcp excluded-address 192.168.200.1 192.168.200.2
ip dhcp pool Maxirede
network 192.168.200.0 255.255.255.252
domain-name Maxirede
default-router 192.168.200.1
dns-server 200.175.5.139 200.175.89.139
lease 0 0 1
ip cef
ip ssh time-out 120
ip ssh authentication-retries 3
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
crypto mib ipsec flowmib history tunnel size 200
crypto mib ipsec flowmib history failure size 200
interface Ethernet0
ip address 192.168.200.1 255.255.255.252
ip nat inside
ip tcp adjust-mss 1400
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
bundle enable
dsl operating-mode auto
hold-queue 224 in
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname [email protected]
ppp chap password 7 ********
ppp pap sent-username [email protected] password 7 *****
ppp ipcp dns request
ppp ipcp username unique
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 1 permit 192.168.200.0 0.0.0.255
line con 0
login local
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 0 0
login local
scheduler max-task-time 5000
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 06/02/2009 - 21:40
  • Hall of Fame,
    Founding Member
Hello Jonas,
this looks like a possible problem with IOS version on the C1721: a dialer string is needed for a dialer interface used for ISDN DDR.
However, I would move the configuration under an ATM point-to-point subinterface if supported:
int atm0
no ip address
int atm0.1 point-to-point
pvc 0/35
if you do the following:
terminal monitor
debug ppp negotiation
debug ppp auth
then
conf t
int atm0
shut
! wait 60 seconds
int atm0
no sh
you can attach the output in a text file
As I've noted at the beginning this may be an IOS version issue.
Hope to help
Giuseppe
j.conceicao Wed, 06/03/2009 - 05:28
Hi Giuseppe
Thanks for your help!
Well I have changed as you asked for but it's still the same.
Thanks again,
Jonas
Maxirede-via-GVT#sh deb
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
shut
00:08:22: %LINK-5-CHANGED: Interface ATM0, changed state to administratively down
00:08:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
no shut
00:10:51: %LINK-3-UPDOWN: Interface ATM0, changed state to down
00:11:24: %LINK-3-UPDOWN: Interface ATM0, changed state to up
00:11:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
Maxirede-via-GVT#sh ver
IOS (tm) C1700 Software (C1700-ADVENTERPRISEK9-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 14:24 by dchih
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
Maxirede-via-GVT uptime is 19 minutes
System image file is "flash:c1700-adventerprisek9-mz.123-26.bin"
cisco 1721 (MPC860P) processor (revision 0x200) with 61759K/3777K bytes of memory.
Processor board ID FOC07380ZCA (1056193944), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Maxirede-via-GVT#
The Configuration file:
Building configuration...
Current configuration : 1831 bytes
version 12.3
no service pad
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
lease 0 0 1
no ip domain lookup
ip audit po max-events 100
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface ATM0
no ip address
interface ATM0.1 point-to-point
pvc 0/35
interface FastEthernet0
ip nat inside
speed auto
hold-queue 100 out
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer string 0,35
dialer-group 1
ip classless
no ip http server
no ip http secure-server
line con 0
login local
stopbits 1
line aux 0
line vty 0 4
access-class 1 in
exec-timeout 0 0
login local
j.conceicao Wed, 06/03/2009 - 08:21
Hi Guys,
I just downloaded the c1700-sy7-mz.124-25.bin and it is working.
Jonas
Giuseppe Larosa Wed, 06/03/2009 - 09:24
  • Hall of Fame,
    Founding Member
Hello Jonas,
nice to hear you have solved: so it was an IOS version issue as suspected.
Hope to help
Giuseppe
