06-02-2009 02:34 PM - edited 03-15-2019 06:20 PM
Any ideas why on remote sites using g729 the silence is heard. on central site g711 work fine. the ccm is 4.1 and the router is 1751-v using fxs.
06-02-2009 03:34 PM
Try these commands:
mgcp behavior g729-variants static-pt
mgcp behavior dynamically-change-codec-pt disable
Also, you can disable the advertising of G729 annex b in the service parameters.
hth,
nick
06-04-2009 06:37 AM
Thanks nicmatth, this work fine on the 2 ways.
I really appreciated that
