*****************Translate specific incoming calls***************
Jun 2nd, 2009
Hi Pros,
I am about to apply the config below into one of our remotes router. Before I do so, I need a second opinion as I new in VOIP.
There is the config, I wrote it myself. More info coming after...
voice translation-rule 7000
rule 1 /60475906/ /40345099/
rule 2 /60475907/ /40345099/
rule 3 /60475999/ /40345099/
voice translation-profile sendToPaidServer
translate called 7000
dial-peer voice 400 voip
description send calls to prepaid router
huntstop
translate called sendToPaidServer
preference 5
destination-pattern 40345099$
session target ipv4:10.x.x.x
dtmf-relay cisco-rtp
fax rate 7200
ip qos dscp cs5 media
no vad
This is what I want this config to acomplish.
I have a dozen remotes that used to dial the three 604 numbers in the config to connect to a prepaid server at the HQ. Last winter,we had issues with the 604 numbers at the HQ,so we changed them for 403,but remote is still not aware about the change. And remotes can only dial local 604 number,all other number are rejected!!
Now I want remote to continue to dial the same 604 numbers as they used(seamless changed).
Hope that I have enough info and I am precized.
Thanks in advance,
Crazy
CrazyDonJuan Wed, 06/03/2009 - 08:23
Applied config,but it does not work as I expected. What may be wrong the config? Please help.
Crazy
Adrian Saavedra Wed, 06/03/2009 - 09:07
  • Gold, 750 points or more
I think you can change two things in your dial peer.
translation-profile outgoing sendToPaidServer
destination-pattern 60475...
Check if it works.
- Adrián.
CrazyDonJuan Wed, 06/03/2009 - 10:03
Hi Adrian,
My prepaid router does not have any dial-peer for 604 number.The destination cannot be 604,this router going to drop the call.
I made the translation because I want to send the call to this router as 403.
AS of the first mistake, I catched that before I applied the config!
Crazy
CrazyDonJuan Thu, 06/04/2009 - 08:57
config still not working even after modification.There is the current config:
rule 1 /6047590699/ /4034509938/
rule 2 /6047590700/ /4034509937/
rule 3 /6047590698/ /4034509934/
dial-peer voice 800 voip
huntstop
preference 2
destination-pattern 403450993[478]$
session target ipv4:10.x.x.x(router with T1 card connected to prepaid server)
fax rate 7200
no vad
Contact at remote said,that nothing happend after typing one of the 604 numbers translated above.
littledavewhite Thu, 06/04/2009 - 09:30
maybe dial peer 800 does not match the pre translated number you are appying the translation on the dial peer that matches the number after translation, it the numbers are coming in on a e1 or t1 put the rule under the voice port.
hope this helps
Adrian Saavedra Thu, 06/04/2009 - 09:34
Check which dial peers are matched when you're calling 604 numbers.
debug voip ccapi inout or show call active voice brief.
Regards.
OK Crazy,
I got a crazy solution for you. I haven't tested it, but it might work...
voice service voip
int lo0
192.168.1.1 255.255.255.255
description translate called number and send to loopback of VGW
destination-pattern 60447590[6-9]
session target ipv4:192.168.1.1
fax rate 7200
no vad
dial-peer voice 401 voip
fax rate 7200
no vad
To follow the logic:
1. The user dials the 604 number
2. The VGW sends the call to the loopback of the VGW with the translated called number.
3. The router sees the call come in with the translated called number and sends it on it's way to the HQ site.
HTH,
Jon
