Preventing access to VLANs
Jun 2nd, 2009
Hi, here is a task i have to accomplish for one of my clients:
VLAN 704 10.23.4.0/24,
VLAN 705 10.23.5.0/24,
VLAN 706 10.23.6.0/24,
I need to seperate these 3 environment so they are not accessible from each other.
VLAN704 has no access to VLAN705 and VLAN706
VLAN705 has no access to VLAN704 and VLAN706
VLAN706 has no access to VLAN704 and VLAN705.
The VLANS are on 4500 L3 switch.
There is existing ACL that could be used:
ip access-list extended ACL-Block
permit ip 192.168.11.0 0.0.0.255 host 10.16.23.51
deny ip host 192.168.11.104 10.16.0.0 0.3.255.255
deny ip 10.16.0.0 0.3.255.255 host 192.168.11.104
Is is good enough to accomodate existing ACL with lines:
deny ip 10.23.4.0 0.0.0.255 10.23.5.0 0.0.0.255
permit ip any any
or something else should be done?
Jon Marshall Tue, 06/02/2009 - 15:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dragan
You could do the following
access-list 101 deny ip 10.23.4.0 0.0.0.255 10.23.5.0 0.0.0.255
access-list 101 deny ip 10.23.4.0 0.0.0.255 10.23.6.0 0.0.0.255
access-list 101 permit ip 10.23.4.0 0.0.0.255 any
int vlan 704
ip access-group 101 in
access-list 102 deny ip 10.23.5.0 0.0.0.255 10.23.4.0 0.0.0.255
access-list 102 deny ip 10.23.5.0 0.0.0.255 10.23.6.0 0.0.0.255
access-list 102 permit ip 10.23.5.0 0.0.0.255 any
int vlan 705
ip access-group 102 in
access-list 103 deny ip 10.23.6.0 0.0.0.255 10.23.4.0 0.0.0.255
access-list 103 deny ip 10.23.6.0 0.0.0.255 10.23.5.0 0.0.0.255
access-list 103 permit ip 10.23.6.0 0.0.0.255 any
int vlan 706
ip access-group 103 in
Alternatively you could look at vrf-lite which provides complete separation on the control plane but this may be more complex than you need.
Jon
Jon Marshall Tue, 06/02/2009 - 15:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Andre
Private vlans are typically used when you have the same subnet but you want to limit connectivity between devices within that subnet.
But Dragan's example has 3 separate vlans using 3 separate IP subnets so i'm not sure how private vlans would be applicable here.
Jon
mahmoodmkl Tue, 06/02/2009 - 21:32
  • Gold, 750 points or more
In addition to the above posts one simple thing i can suggest is not to create SVI's on the L3 switch which will disable the routing among them.
Mahmood
Dragan Milojevic Thu, 06/04/2009 - 07:14
Thank you gents.
This ACl will be live for two months only, after that subnets will be removed. SVIs are must thins on this switch since the switch is used for other subnets/SVIs. I think acl will work as temp/quick solution.
Thank you all for responces.
