Questioned devices DFM
Jun 2nd, 2009
Good day,
Hopefully someone can point me in the right direction. I have an environment that contains many different devices and approx 2000 devices. I have discovered approx 1/3. Looking at DFM(ver4 Solaris), I have many devices in the questioned state. Looking in the logs of DFM.log, I find the following:
ADTM-N-TMG2_STATUS_START-Last discovery started at 03-Jun-2009 09:25:16
[03-Jun-2009 09:25:15+884ms] [email protected] Discovery #7
ADTM-E-AD_EACCESSADDRESS-While discovering '',
Qualified access address not found
ADTM-N-TMG2_STATUS_COMPLETE-Last discovery completed at 03-Jun-2009 09:25:16
But....doing a nslookup on a working device vs a "questioned device" shows the exact oppposite:
Discovered and working device:
bash-2.05# nslookup lc-rtr-121
*** can't find lc-rtr-121: Non-existent host/domain
Non - working device from logs:
bash-2.05# nslookup lc-rtr-101
Any ideas? Its as if DFM has stored a different domain suffix for the device?
Overall Rating: 5 (5 ratings)
Joe Clarke Tue, 06/02/2009 - 17:32
Under DFM > Device Management > Rediscover/Delete you will find a reason for why the devices are questioned. What is that reason? What version of DFM is this? DFM 4 is not a valid version.
pieterddejong Tue, 06/02/2009 - 18:20
Sorry, there are a few issues. The devices mentioned above are in the "learning state" and stay at 10% completed. No error codes or messages just the extract from the log.
DFM would be version 2.0.3 (no idea where I got the 4 from?)
Joe Clarke Tue, 06/02/2009 - 18:46
Learning at 10% indicates a problem with one of the daemons. Post the output of the pdshow command. Is the fully qualified hostname of this server resolvable?
pieterddejong Tue, 06/02/2009 - 19:40
Attached is the pdshow. The server hostname is resolvable:
[email protected]$ nslookup cwksvrc101p
Here's what I have found:
1. When the CW is looking for the device, it is resolved to
The device is configured with:
ip domain-name
The CW server also being part of
Think this is where it gets a bit confused?
Joe Clarke Tue, 06/02/2009 - 19:50
This all checks out. Post the daemons.log, and the output of ps -efl.
Joe Clarke Tue, 06/02/2009 - 20:40
Your DFM databases contain bad data. You will need to reinitialize. I also recommend you upgrade to LMS 2.6 with DFM 2.0.13 to prevent this from happening in the future. LMS 2.6 can be downloaded from .
To reinitialize the DFM databases, do the following:
/opt/CSCOpx/bin/ dsn=dfmInv dmprefix=INV
/opt/CSCOpx/bin/ dsn=dfmEpm dmprefix=EPM
/opt/CSCOpx/bin/ dsn=dfmFh dmprefix=FH
Then delete /opt/CSCOpx/objects/smarts/local/repos/icf/DFM.rps. Then restart dmgtd.
pieterddejong Tue, 06/02/2009 - 20:43
Thank you,
I will get permission to do this. Just quickly, I do not require any more licensing to go 2.5.1 to 2.6? I am just making sure.
I will update post when I have done the above.
Also, how could you tell database corrupt?
Joe Clarke Tue, 06/02/2009 - 20:50
No, the 2.5 license will work with 2.6. LMS 2.6 is a free upgrade for 2.5.1 users.
There were sync errors in the daemons.log that pointed to a problem with conflicting data in the various DFM databases.
