CME overlay/Shared line
Jun 2nd, 2009
Hi all, I have the following config. My goal is to have 5010 ring all phones, with the ability for a max of 4 active 5010 calls since I have 4fxo lines. If all are busy or no answer goes to 6000. It seems that currently I can only get to inbound to 5010 and answer the third and 4th go directly to voice mail am I missing something? Thanks in advance!
voice-port 0/1/0
connection plar 5010
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
dial-peer voice 6000 voip
destination-pattern 6000
session protocol sipv2
session target ipv4:192.168.2.2
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn 1 dual-line
call-waiting ring
number 5001
name Joyce
call-forward busy 6000
call-forward noan 6000 timeout 20
ephone-dn 2 dual-line
call-waiting ring
number 5002
name Tricia
ephone-dn 3 dual-line
call-waiting ring
number 5003
name Brittany
ephone-dn 4 dual-line
call-waiting ring
number 5004
ephone-dn 5 dual-line
call-waiting ring
number 5005
name Todd
ephone-dn 6 dual-line
number 5010
name MainNumber
call-forward noan 6000 timeout 10
huntstop channel
no huntstop
ephone 1
device-security-mode none
mac-address 0022.9004.3E9C
username "joycem" password 12345
button 1o1,6
ephone 2
mac-address 0019.06A2.1032
username "triciac" password 12345
button 1o2,6
ephone 3
mac-address 0022.9004.7C91
username "brittanym" password 12345
button 1o3,6
ephone 4
mac-address 001B.5452.C95A
button 1o4,6
ephone 5
mac-address 001E.136C.29A3
username "toddw" password 12345
button 1o5,6
Nicholas Matthews Fri, 06/05/2009 - 16:07
  • Red, 2250 points or more
You really need something like this:
ephone-dn 1 dual
number x
! overlay
no huntstop
hunt channel
ephone-dn 2 dual
number x
! overlay
no huntstop
hunt channel
ephone-dn 3 dual
number x
! overlay
no huntstop
hunt channel
ephone-dn 4 dual
number x
! overlay
ephone 1
button 1o5,1,2,3,4
ephone 2
button 1o6,1,2,3,4
ephone 3
button 1o7,1,2,3,4
ephone 4
button 1o8,1,2,3,4
etc.
In this case you have only given 5010 2 channels. If you want more channels you have to configure the same DN on multiple ephone-dns.
-nick
paolo bevilacqua Fri, 06/05/2009 - 18:51
  • Hall of Fame,
    Founding Member
My recommendation is that you update to latest CME, that will give you both parallel hunt-group, and octo-line DNs, that will allow you to do blast calling in a much easier way.
Note generally speaking blast calling is not the best way and is asked by customer that really do not weight the consequences and possible alternatives.
Nicholas Matthews Sat, 06/06/2009 - 06:49
I thought about octo-lines, and it is much easier to configure, but it slightly changes the dynamic here.
You can't overlay octo lines, which means the users would have two separate buttons instead of 1 they have right now. If that's cool with the users, I would do that.
The configuration is much simpler:
ephone-dn 1 octo
number x
busy-trigger 4
ephone 1
button 1:2 2:1
ephone 2
button 1:3 2:1
ephone 3
button 1:4 2:1
ephone 4
button 1:5 2:1
etc
