Port open for pptp
Jun 2nd, 2009
Hi i'm using a cisco 857 router, my problem is when i connect to other network using windows pptp from our internal to outside i can't connect. It only reach up to verifying username and password then it will be cut off and it will give me error 619. A connection to the remote computer could not be established, so the port used for this connection was closed.
and 2nd problem is when i connect vpn from outside to our internal office. I can ping and remote everything but i can't access our wss site at my internet explorer that is using port 80.
Kindly check the attached config of my router
Thanks for your advise
Giuseppe Larosa Wed, 06/03/2009 - 04:26
Hello Marc,
see RFC2637
There are two parallel components of PPTP: 1) a Control Connection
between each PAC-PNS pair operating over TCP and 2) an IP tunnel
operating between the same PAC-PNS pair which is used to transport
GRE encapsulated PPP packets for user sessions between the pair.
Section 1.3
So both must be allowed to have a successful PPTP vpn.
GRE uses 47 GRE General Routing Encapsulation [Li]
You need to update the inspect rules accordingly.
Hope to help
marc.sanico Wed, 06/03/2009 - 19:49
Hi Giuseppe thanks for the information. What command should i add and where should i put it?
