Internet monitoring tool
Jun 2nd, 2009
Hi expertz,
I'm trying to look for an internet monitoring tool that could monitor/report the bandwidth usage per ip, which site per ip, most visited site, etc...Also is there anything outhere that works on WinXp, via snmp, and open-source? All our devices are Cisco but Ciscoworks is too much for us so we were looking for an open-source.
redrobish Wed, 06/03/2009 - 14:16
I've tried this one but I cannot see how this can report/monitor which site is visited, most bandwidth used by each user, etc...or I missed to do something when using it like plugin maybe?
thanks for the reply
Jan Nejman Thu, 06/18/2009 - 06:19
you can configure netflow on your router/switch and then you can use an external application/collector which will display all informations about traffic (src/dst IP addresses, ports, #bytes, interfaces), etc. Check the webpage: or where is more information about it.
redrobish Thu, 06/18/2009 - 15:19
Thanks for replying. I'm looking for a snmp monitoring software not using any netflow since I don't have control on the router. However snmp can't do what i'm looking for so this case is closed.
thanks anyway.
