Password Recovery for Wireless Lan controller
Jun 2nd, 2009
Hi, I am new to Wireless Lan Controller.
I just wanted to reset the password for the Controller. Can anybody help me with this. link/procedure anything will be appreciated.
Thanks & Regards,
Overall Rating: 5 (1 ratings)
colin.lynch Wed, 06/03/2009 - 05:51
1.Enter reset system at the command prompt.
2.At the prompt that asks whether you need to save changes to the configuration, enter Y or N. The unit reboots.
3.When you are prompted for a username, enter recover-config to restore the factory default configuration.
The WLC reboots and displays the Welcome to the Cisco WLAN Solution Wizard Configuration Tool message.
jvalin__s Mon, 06/08/2009 - 20:51
I am unable to open the cli as well as the gui of it. Its continuously asking for password. Is there any method to go to rommon mode and reset the password of it.
Thanks & Regards,
Leo Laohoo Tue, 06/09/2009 - 14:10
Can you be more specific with "I am unable to open the cli as well as the gui of it"?
Are you physically facing the appliance or are you doing all of this remotely?
weterry Tue, 06/09/2009 - 18:46
I think they mean that they can not type "reset system" since they can't log in in the first place.
The key point to be made is that you need to restart the controller. So power it off if you can't login. Then console in to the controller and type "Recover-Config" as the username. This will default the configuration and allow you to start over with a new username/password.
There is no other password "recovery".
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
