Server initiated connection issue with CSM-S
Jun 2nd, 2009
Hello
I am trying to configure the server initiated connection on the CSM-S working in bridge mode.
As far as I was able to check, the SYN packets are leaving through the CSM. The SYN-ACK packets are coming to the CSM from the client vlan but, somehow, they are not passing the load-balancer.
I've already configured the direct-access vserver/sfarm and the communication initiated from the outside word to the server that is trying to establish a connection outside works fine. It failed in the oposite way.
If anybody knows how I could fix this issue please let me know.
Lucas
Gilles Dufour Thu, 06/04/2009 - 01:33
  • Cisco Employee,
Lucas,
is the SYN/ACK coming back on the different vlan than where the SYN was sent ?
Try to have only 1 gateway and make sure this is the one going in the same direction as traffic coming in.
CSM does not like asymetry.
G.
lukaszkhalil Thu, 06/04/2009 - 02:50
Hello
The SYN/ACK are comming on the client vlan and the SYN was sent via the server vlan.
They are both bridged.
Lucas
Gilles Dufour Thu, 06/04/2009 - 04:18
  • Cisco Employee,
If the client and server vlan are bridged, you should not need a vserver/serverfarm for communication from client to server.
Could you try removing it and see if that helps.
What version do you have ?
Can you get a 'show mod csm x var'.
Gilles.
lukaszkhalil Thu, 06/04/2009 - 04:49
Yes, I tried but it doesn't work.
I am using CSM-S 2.1(4)
I've attached the output of the sh mod csm x var
Lucas
Gilles Dufour Thu, 06/04/2009 - 09:27
  • Cisco Employee,
do you have static nat ?
You could try to configure the following
variable ROUTE_UNKNOWN_FLOW_PKTS 3
G.
lukaszkhalil Tue, 07/07/2009 - 08:11
Hello
I apologize that I am replaying so late but I was on holidays.
I will check this value by the end of the week.
lukaszkhalil Fri, 07/10/2009 - 04:20
Hello
Unfortunately this command doesn't work in bridge mode. Below is what we saw:
Router(config)#module contentSwitchingModule 3
Router(config-module-csm)#variable ROUTE_UNKNOWN_FLOW_PKTS 3 ?
LINE
Router(config-module-csm)#variable?
variable
Router(config-module-csm)#variable ?
WORD variable name
CSM3: invalid value for variable ROUTE_UNKNOWN_FLOW_PKTS
01:21:34: %CSM_SLB-4-ENV_VARIABLE: Module 3 warning: ROUTE_UNKNOWN_FLOW_PKTS is applicable to exclusive ROUTED mode only, config accepted.exit
